I am getting dynamic memory allocation errror. Even though storage is available on my laptop I am getting licence error.Where should I clear the memory to solve this error.Please help me out.
Please describe your model:
How many mesh elements, size, frequency, and any solver settings you have applied?
The antenna itself should not be solved with RL-GO, this should remain on the default setting. Usually with RL-GO solutions, the antenna is replaced with an equivalent source to reduce memory requirements. The bumber can be solved with RL-GO.
Alternately, everything is solved with MLFMM, but this could be computationally expensive, not suitable for solving on a laptop.
If you cannot share more details of the model, it would be best to request support. Go here and click Contact support.
