Error ID 760
I got a 'Segmentation Violation' error while running a simulation which worked before. This model is reconstructed by using a .sta file which is result of first step of simulation. the second model worked before properly, but I just translated some nodes manually, would be the reason of error?
| ABNORMAL END |
| Segmentation Violation |
| TRACE BACK : |
INITIALIZATION
ERROR ID : 760
** ERROR TRAPPED
It is very general error and may be the error is due to contact.
0 -
Thanks for your response ANK,
This model worked before very well. I just translated some nodes a little bit and faced this error after. Probably, the problem comes from using .sta file.
0 -
Segmentation violation is general error and may be due to modelling error.
RADIOSS writes out formatted output files from RADIOSS Starter and RADIOSS Engine. It can be *.STA file or a *.STY file. The purpose of the *.STA-file is to save the state of element and then make it possible to include it into a _0000.rad file for RADIOSS Starter.
0 -
Yes, this is exactly what I have done before. Since I do a simulation in 2 steps, the first simulation aimed to provide the state of the elements after a certain loading condition. Then, the result (.sta) file is exploited to generate second model with new loading condition with added some parts. These two step worked before very well. Now, I decide replicating second simulation with a new condition that some nodes are moved a bit. After doing translation, I run the model and this error arises. As without translation it works, I just conjecture that it caused the error.
0 -
Error id 760 is a generalized modelling error. Please share the strater out (_0000.out) file of the error trapped model so that we can review and can sort out the issue.
0 -
This seems like an issue with the groups in the model.
Please run the model checker (Tools>>Model Checker>>RadiossBlock) so that it will list the modelling errors in the model.
If the issue persist please share the model file through the secure dropbox link.
