Hello All,
I have to linear static analysis using Plastic material. Can u tell me what are the material properties i should give as a input?
Which material card should i use in optistruct?
Thanks & Regards,
Rahul
Rahul K,
You can do a Quasi static analysis with NL material. I think Linear static will ignore non linear properties of the material.
NLSTAT is the analysis type and MATS1 is the card where you can input plastic properties.
Thank you Prakash
