Hello !
I dont have much knowledge about hyperworks and I work on a project about mechanical shocks but i'm having problems with control cards,like Tstop in RUN and Tfreq in ANIM DT and TFILE.
Please can i have an explication.
thanks a lot .
please refer to Radioss help (help>hyperworks help home>radioss or F1).
Tstop is the simulation end time.
Tfreq is frequency to write either animation or history plot file.
Hi mohamed amine
Tstop is for defining the termination time for the run. The simulation will terminate when the time reaches the Tstop value.
Tfreq is for defining the start time and frequency for writing the animation files. This will create animation files of the simulation with specified intervals which you can view in Hyperview
Tfile is the request for time history file(T01) for plotting graphs and plots.
DT is the keyword used to impose minimum time step values for corresponding element types or nodes
