solver problem
Altair Forum User
Altair Forum User
I am Having some problem in radioss solver .It shows the following message:-
RADIOSS Starter version 13.0
Command line arguments help:
  -help           / -h               : Print this message
  -version        / -v               : Print RADIOSS release information
  -input [FILE]   / -i [FILE]        : Set RADIOSS Starter input file
  -nspmd [INTEGER] / -np [INTEGER]   : Set Number of RADIOSS SPMD domains
  -nthread [INTEGER] / -nt [INTEGER] : Set Number of SMP threads per SPMD domain
  -notrap                            : Disable error trapping
 ==== End of solver screen output ====
 ==== Job completed ====
  • Altair Forum User
    Altair Forum User
    edited February 2017
    Hi Ayush,
    Can you share the .out files?
  • Altair Forum User
    Altair Forum User
    yes sir sure.I had just drop that in your secure file dropbox
  • Altair Forum User
    Altair Forum User
    Hi Ayush,
    Keep the rigid elements separately in a component collector with no card image, material and property. And i recommend you to check the rigids defined in the model.It is not recommended to set a node of the mesh as the master node of a rigid body. Try to model was master node (independent node) with calculate node option for the rigid bodies.
    Also check if the slave nodes are dependent on other rigid bodies. If you adding mass in the master node of the rigid body, it is better to add in the master node by card editing the rigid body from Rbody Manager.
    Please view this webinar https://www.youtube.com/watch?v=kYWyjCfSnkU&index=3&list=PL1u26y75SCrA_BOCLaSewVCNY7xRvCTnA which details about defining rigids in RADIOSS.
  • Altair Forum User
    Altair Forum User
    I am not able to do it, sir.I request you to please do it so that I could move forward.
  • Altair Forum User
    Altair Forum User
    The corrected model has been sent..
