I want to perform a turbomachinery analysis using AcuSolve, but the turbomachinery module/entity is not there. Any idea?
Thank you.
SuperCFD
There is no specific module for Turbomachinery available in acuconsole.
If you meant rotary machinery, then see this video for intro.
The plugin is available with HW12.0.310. Note it is meant for low mach numbers applications like pumps (no turbo!)
>http://www.youtube.com/watch?v=wwqRtwKknyo
Yes, that's it. But a bummer, thanks!
i am performing the cfd analysis of a water jet propulsion. I´m not surre if my approach is correct, but if it could help you,
I can provide you my cfd data.
Thank you
