1D BEAM ANALYSIS
I am currently carrying out a 1D beam analysis. My results and the contour on my beam seems patchy and unclear.
I have attached the file of the beam and results for you to understand.
It is a distributed load of 150N between 32mm-109mm and 222mm-299mm.
Could you please tell me how to make the contour line more visible. I have tried to change the range, but it did not make a difference.
Thank you,
Yousif
Oh, I thought it is due to graphic problem. because when I open h3d file directly, it is not patchy
when I open hyperview via menu button 'View' on optistruct solver window, it is always patchy.
0 -
Hi tinh,
Could you send me the hm model of the result. That is the exact result I wanted. Thank you.
0 -
