Can I request H3D file to be generated at each subcase in Optistruct, instead of one file at the end of all subcases.
Hi Ataul,
Try OUTPUT>>H3D>>ALL>>BYSUB. You can find this in ControlCards.
Thanks Prakash. This option is working out.
But the H3D files are getting generated only after the whole run is completed. Is it possible to get H3D after each subcase is finished.
I will check and update to you.
There is no option to get the h3d instantly.
