Hey,
is it possible to connect 2 cubes with lines? The idea is that I have 2 cubes and I want to connect 2 facing sites with lines to simulate a fiber connection. After this I want to use the fibers tu test some loading conditions and test dhe behavior of this structure with a cycling loading approach. That indicates my next question which property is the best definition in Hypercrash to use the lines as fibers with a dfined diameter?
I uploaded my Hypermesh project.
Additinally i uploaded a picture of the idea. I want to create these lines as a kind of connectors between facing nodes. (Look at the picture)<?xml version="1.0" encoding="UTF-8"?>
Thank you very much.
Best
Max
