🎉Community Raffle - Win $25
Join and Win
How to Create widgets like label frame in HM framework tab
User: "Altair Forum User"
Updated by Altair Forum User
Hi ,
I am trying to create a UI in the Tab  in HM itself.  i inserted some widgets like label frame, radio button , button etc.
  • in this label frame not showing , how to create a label frame i tried this code with help of   hwtk GUI toolkit.
Kindly help me to solve this issue and guide me how to create a UI in HM _framework
I attached the image and code which i used for your reference
################################################CODE##################################################################
#setting the mainframe
        set mainfrm [frame .frm1]
    # Adding the Tab
        hm_framework addtab 'Queries' $mainfrm
    # creating a subframe
        set subfrm [frame $mainfrm.frmmain1 ]
        pack $subfrm -side top -fill both
    # creating lable
        #pack [label $subfrm.lb1 -text 'Query Report Generation' -width 60] -side left -fill x -expand 0
    # creating label frame for TGW
        pack [labelframe $subfrm.lblfrm -text 'TWG_Report'] -pady 4
    # #Radio Button in the label frame
         pack [radiobutton $subfrm.rdbtn -text 'TWG'] -side top -fill x -pady 2
    # creating a screen shot button
        pack [button $subfrm.btn -text 'snap shot'  -command 'On_Select_SnapShot' ] -side top -fill x -pady 2
    # creating a Presentation for TGW
        pack [button $subfrm.btn1 -text 'Genrate'  -command 'Generate_Report' ] -side top -padx 2 -pady 2
output which i got
BUTTON AND RADIO BUTTON AND IS THERE BUT LABEL FRAME IS NOT THERE.HOW TO CREATE THAT LABEL FRAME
Thanks & Regards
Suresh Kumar V
