hello,
optistruct>> I have applied a load of 565 pounds (equivalent to 2500N) on a leaf spring.The simulation results say the spring will deform to a length of 38(1.5 inch) mm to failure.The failure index is 2.744.Is there a way to determine at which load the failure will occur.It is obvious the spring wont sustain 565 pounds as the failure index is way to high.So it would fail before that but the question is at what load i.e at 200 pounds , 250 pounds etc etc ?
