Can i translate from Block to Bulk data my model, without losing assighnments between components,props and mats?
You can try opening Hypermesh, User Profile RADIOSS Bulk; then import fe-model and set RADIOSS Block in the pull down menu. The assignments should be still there when importing the Block-Model.
What definfitely works is importing the block model in HyperCrash and export as Nastran..
