Team,
What is the difference b/w shortest edge, minimal height and normalized height under check element setting panel and its significance?
Minimum element lengths are calculated using one of these methods:
•The shortest edge of the element. This method is used for non-tetrahedral 3D elements.
•The shortest distance from a corner node to its opposing edge (or face, in the case of tetra elements); referred to as 'minimal normalized height'.
• Minimal height, which is the same as minimal normalized height but without a scaling factor.
Each check can be set to use a different solver’s check method, or user can set every check to use the same method.
Please go through the Help Menu on the same for more description on this topic.
Thanks for update.
> what is not tetra. you mean to say 2D and hex?
>minimal normalized height & Minimal height you mentioned it is for tetra elements. It means if we have a crash model having a shell elements then we can not use these options.
> In Radioss model time step(L/c) is calculated based on which L-Min element size(shortest edge, minimal height and normalized height ).
I haven't find and significant related to above in help menu please share a link or forward:
Hi Sumit,
Please find the attached document on the same.
Thanks for reply.
>Now what is scaling factor in minimum height option? How to decide the same? Can you share some pic showing minimum height in element just like it is mentioned in minimal mormalized height?
>Can you share some document showing Radios consider shortest edge to calculate time step? And if it can be change then what factors makes one to consider while selecting shortest edge, minimal height and normalized height for calculating minimum element size?
In the above shared document it is written that the scaling factor used is 2/sqrt(3.0). Unfortunately we don't have much documents on this currently.
Please go through Shell Elements in RADIOSS Theory Manual where this concept is explained.
