Run analysis using tcl command
I used following commands to run analysis but it created only h3d, fem, out, and stat files.
I open out file and it says checking only completed. so there is no analysis process.
#create new folder
md 'implant static analysis$i'
*createstringarray 4 'model=1' 'overwrite=1' 'title=0' 'result=0'
*writeh3dwithoptions 'C:/Users/sihao/Desktop/COOP/2018 Summer/Dental Implant/tcl/implant static analysis$i/Beam$i.h3d' 1 4
*createstringarray 1 'CONNECTORS_SKIP '
*feoutputwithdata 'C:/Program Files/Altair/2017-edu/templates/feoutput/optistruct/optistruct' 'C:/Users/sihao/Desktop/COOP/2018 Summer/Dental Implant/tcl/implant static analysis$i/beam_r_4_l_10$i.fem' 1 0 2 1 1
'C:/Program Files/Altair/2017-edu/hwsolvers/scripts/optistruct.bat' 'C:/Users/sihao/Desktop/COOP/2018 Summer/Dental Implant/tcl/implant static analysis$i/beam_r_4_l_10$i.fem'
Thank you
Hello @tinh,
I added -analysis at the end but it doesnt seem to be working. I find that there are err-5280.out and other files popped out when running.
Also, is there command for opening graphical interface to monitor the process? that solver view?
Thanks in advance,
Alan
It is
exec [hm_info -appinfo SPECIFIEDPATH wish] [file join [hm_info -appinfo ALTAIR_HOME] hwsolvers scripts hwsolver.tcl] -solver OS -screen 'C:/Users/sihao/Desktop/COOP/2018 Summer/Dental Implant/tcl/implant static analysis$i/beam_r_4_l_10$i.fem'
Please refer to
Hello @tinh,
<?xml version="1.0" encoding="UTF-8"?><?xml version="1.0" encoding="UTF-8"?>
#create new folder
*writeh3dwithoptions 'C:/Users/sihao/Desktop/COOP/2018 Summer/Dental Implant/tcl/implant static analysis$i/Beam$i.h3d' 1 2
'C:/Program Files/Altair/2017-edu/hwsolvers/scripts/optistruct.bat' 'C:/Users/sihao/Desktop/COOP/2018 Summer/Dental Implant/tcl/implant static analysis$i/beam_r_4_l_10$i.fem' -analysis
Alan
Is this the one you are looking for? I open one of its OUT file. Run Type indicates Check Only
Thank you
Alan
Did you use this command? I said about it on above post
Hello @tinh,
I did. And it indicates that check only
if i ran it manually, it is working as shown below.
Thank you!
Alan
could you try again with below ? (add -analysis)
exec [hm_info -appinfo SPECIFIEDPATH wish] [file join [hm_info -appinfo ALTAIR_HOME] hwsolvers scripts hwsolver.tcl] -solver OS -screen -analysis 'C:/Users/sihao/Desktop/COOP/2018 Summer/Dental Implant/tcl/implant static analysis$i/beam_r_4_l_10$i.fem'
And, is there any control card in your inputfile that indicate 'check only' ? Please confirm
Hi @tinh,
Thank you very much! basically there is a check control card. I deleted it and solver does analysis now.
One more thing, since it is a for loop. what command is used to close the hwsolver after analysis is finished?
Alan
Hi
Invoke optistruct.bat with option '-analysis'
