Why my model is considering non design component for optimisation. I've assigned the design and non design properties correctly to both components respectively. ?
Dear Niranjan,
You can check for 'Connectivity Issue' & check the faces for the same component.
You need to equivalence the same & proceed further for Optimization.
Meanwhile if you still have the same issue after this, then kindly share your model in below provided drop-box link.
Nitin,
The problem with your model file is you have used 'Volume' as response , so it is taking in effect in design & non-design region.
You can select 'Volume Frac' as response in your model file & re-run it should give you desired effect.
Meanwhile i will share you modified file with you on your email id.
For Further information regarding this issue , you can refer below provided link -
