Deformation
Hi Antonio,
Is it plot of plastic strain?
Where are you applying the loads?
From the plot I presume you are apply the loads in the top of the semi elliptical block, is that correct?
0 -
Altair Forum User said:
Hi Antonio,
Hi Prakash Pagadala,
this is the model.
<?xml version="1.0" encoding="UTF-8"?>This is the analysis. I want to do an analysis of plastic deformation.
Can you help me?
Thanks in advance for assistance.
0 -
You are checking Displacement plot.In result type change Mag to Z axis and check displacement.
0 -
where can I find control card?
0 -
Create your 'Load step' and then Card edit. There're OUTPUT options.
0 -
Could you set Result type to strain and plot results?You have shared displacement plot.
0 -
Good morning
My problem is wrong deformation of two solids. you look at the image. near the arrow can be seen overlapping cylinder mesh with meshes of the plan. probably the program does not see well the area of the contact to me determined. can you help me?
Thanks in advance for assistance and disturb.
