Hi Team,
How to run a acusim job using GPU ?
Thanks in advance.
-Rajesh
Rajesh,
Should be as easy as the following:
1.) Make sure your GPU is set to 'exclusive mode' by using the following command: nvidia-smi -i 0 -c 1
Note that this assumes the compute GPU is device 0
2.) Then run AcuSolve using the -gpu option: acuRun -nt 4 -np 4 -gpu
Note that we have seen the best success when using 1 multi-threaded MPI task per GPU.
