i would like to load a pressure on the interface of my system. Is it possible to put a pressure on a surface, without that this surface is an inlet or outflow?
Thx
I am not sure if it really makes sense to have this type of BC. Are you trying to simulate a flexible body ?
Anyways, AcuConsole does seem to allow that kind of BC. You would need to set the correct precedence if using a mix of BC.
-Advanced Options - Nodal Boundary Conditions - Pressure
You can also apply pressure using Element Boundary Condition, but it is a bit dangerous and not recommended to do so for internal nodes (Nodal BC) and or surfaces (Element BC). What is the scenario where you want to use a boundary condition on an internal surface?
