Explicit dynamic analysis
I have set up model with all card image in optistruct for my problem. I want to perform explicit dynamic analysis on it. So please tell me how to define card image for explicit dynamics analysis. Also, share link for some tutorial. I found one loadstep called geom explicit dynamics. can you tell me how to use that.
Thanks George
Can you tell me how to do that Radioss integration.
0 -
Hi Bhushan,
Geometric nonlinear analysis in OptiStruct is provided through an integration of the RADIOSS Starter and RADIOSS Engine via a translator. Transparent to you, OptiStruct input data is directly translated into RADIOSS input data. The RADIOSS Starter and RADIOSS Engine are then executed and the results are brought back into the OptiStruct output module to export the different output formats.
