I need help. I'm working on a linux based cluster(bash batch mode) and I am using it to calculate a case with acusolve. The case is computing and I'm downloading results to my PC with Win7 via FTP connection, but unfortunately I cannot read the data .Log on my PC's AcuFieldView because it's giving me an opening file error. What's more, in acuprobe I cannot see Output Surface in the value tree as it is when I compute anything on my PC. Is it because the case was calculated in Linux and I can't open the results in Win aplication? Should I then instal a Linux on my PC as well, then install the HW package and it's the only way to see the results? That's quite strange I think...
Regards
