Is there any tutorials or reference exercise in order to learn MFLUID in optistruct for modal analysis?
Regards
Unfortunately there is no tutorial available on MFLUID. I will check if there is a model file available which I can share with you.
thanks
Any model available? Thanks
Pfa
Thanks, I'll check it
done, perfect, and the freq goes down.
Thanks
The same file working at my end. Can you assign the property and check if tha works?
If I want define a more complex surf (without use zfs)? For example a cycler with a piston (so the volume of fluid is the volume of the cylinder minus the volume of the piston)?
Thank
Hi
I think you need Zfs in this case
