I am a beginner in hyper-mesh, don't understand what is the error talking about./emoticons/default_sad.png' srcset='/emoticons/sad@2x.png 2x' title=':(' width='20' />
This is usually because of incorrect or insufficient BC's, Model not being connected properly with other components, incorrect model units etc..
Thanks for the reply, as the model was import from Inspire so I think the connection should be no problem.I will check the BC.Thank you/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
