default settings saved in a template file
User: "Altair Forum User"
Updated by Altair Forum User
Hi all,
I have a query regarding the default settings under the preferences tab in Simlab 2017. Is the default settings saved in a template file(.xml) or some other format which can be accessed by the user and altered later according to the requirement. I have to re-visit preferences tab to change the settings.
Regards
Rishabh
1 - 3 of 31
    User: "Rahul Rajan_21763"
    New Altair Community Member
    Updated by Rahul Rajan_21763
    Two ways you can achieve this.
    Check .ini file in below location.
    C:\Users\rahulr\.Altair\SimLab_V2017\simlab
    or
    create environment variable with name
    SL_USER_DEFINED_SYSTEM_SETTING_FILE
    and pointout .ini file path.
    OP
    Hello
    Thank you Mr. Rahul for addressing my query.,I was able to locate the file..
    Regards
    Rishabh
    Thanks for the update.
    Note:In future, please create a new post for the new topic.
