🎉Community Raffle - Win $25
Join and Win
Invalid mesh error
User: "Altair Forum User"
Updated by Altair Forum User
If any cad model is being imported, when the mesh generation is clicked then it's always showing the same result of ' invalid mesh error ' always.
The required screenshots have been uploaded.
This is the situation to every cad model. So I have tried many times uninstalling the software and reinstalling it again for around 5-6 times. But this has been continuously repeating.
So please help me as soon as possible.
Hope you do the needful.
Thank You
1 - 5 of 51
    OP
    Thank You
    User: "ydigit"
    Updated by ydigit
    Please post your CAD and .acs files and the error file? *Meshsim.txt?
    OP
    Thanks for the reply.
    But I don't have any screenshots of it. I have re-installed OS. Now it's working.
    There's a problem with source.
    User: "acupro"
    Updated by acupro
    Based on the images supplied previously, it appears the directory for the mesh output was changed from the default MESHSIM.DIR, thus the automatic loading of the mesh into AcuConsole could not be accomplished.  So although the mesh was generated correctly and completely, AcuConsole did not know where to look for it.  You could import the mesh manually at that point.  But if it's working now, all is good.
    OP
    Le 16/06/2017 à 04h43, VSSrinadh a déclaré:
    Si un modèle CAO est important, cliquez sur la génération de maillage, le résultat toujours 'erreur de maillage invalide' s'affiche toujours.
    Les captures d'écran requises ont été téléchargées.
    C'est la situation à chaque modèle cad. J'ai essayé de répéter plusieurs fois le logiciel et le nouveau programme de réinstallation environ 5 à 6 fois. Mais cela a été répété continuellement.
    Alors aidez-moi le plus vite possible.
    J'espère que vous faites le nécessaire.
    Je vous remercie
    Capture dCapture dCapture d
