Hello, I am doing drop test in Radioss and got an error in node group definition as DUPLICATE NODE ID =3
Hi Ketan,
Check your model for any duplicate elements.
Please see the post below:.
Thanks sir. I am running the analysis and it shows remaining time =310000 sec. How do I reduce this run time?
To reduce the total simulation time you can impose a time time step using the keyword /DT/NODA/CST in engine file.
The input format is /DT/NODA where Tsca is 0.9
Tsca Tmin
Please refer the video below for timestep in Radioss Explicit.
https://altair-2.wistia.com/medias/o0bfml9ah5
Thanks sir
