Hi all,
while running topology optimization file in optistruct I'm encountering the following error, can anyone please help me out with this
*** ERROR # 1000 *** in the input data :
Incorrect data in fiels # 5.
Thanks and regards
Manohar Bandike
Hi @Manohar_Bandike
Please share the entire .out file
Hi all
problem got solved, error occured because RBE3 elements were attached with RBE2 elements, all the elements were config edited (updated) to RBE2 in Hypermesh.
Hi @Prakash Pagadala
pls find the .out file attached
@Manohar_Bandike
Thank you for update,
Hi all problem got solved, error occured because RBE3 elements were attached with RBE2 elements, all the elements were config edited (updated) to RBE2 in Hypermesh.
