*** INTERNAL PROGRAMMING ERROR # 8006 ***
Altair Forum User
Altair Forum User
Hi, I'm getting the following error while trying to run a modal analysis in Optistruct. Could anyone help me make sense of this?
ANALYSIS RESULTS :
ITERATION   0
 *** ERROR # 825 ***
 The run will be stopped due to the previously encountered fatal error
 from the element generation routine in preprocessing:
    Number of failed elements = 1
  Last encountered error code = 15
 The previous error is encountered in subroutine prpdrv.
 This error is issued in subroutine elqcdrv.
 Data block effmas not in data manager dictionary.
 * DATAMANAGER ERROR in subroutine 'locateit'.
 ****  Error 8006 in datamr() during 'locate' operation.
     Data block name 'effmas'.
     Current memory allocation  8166 MB,
    Unused memory              6248 MB,
    Number of blocks: 280 used, 5 free.
     Call arguments 0, 0.
 *** INTERNAL PROGRAMMING ERROR # 8020 ***
 Failed database modify command:  Locating array effmas.'
 * DATAMANAGER ERROR in subroutine 'LOCATE'.
 This error occurs in module 'wrtdrv'.
Welcome!
  • Altair Forum User
    Altair Forum User
    edited August 2018
    Hi @ShaoibShaikh
    Can you please share the entire .out file?
  • seyilmaz
    seyilmaz Altair Community Member
    edited October 2018
    Any updates on the topic?
    I receive a similar error:
     A fatal error has occurred during computations:
      *** ERROR # 825 ***
         Number of failed elements = 2
       Last encountered error code = 99
  • Altair Forum User
    Altair Forum User
    edited October 2018
    Hi @seyilmaz
    Can you let me know which version of HW you are using?
    If the application is not updated, I request you to update the solver to the latest and try again.
    If that doesn't help, please share the .out file.
  • seyilmaz
    edited October 2018
    Hello Prakash,
    I have solved the problem. It is the CBUSH definition for me. When I defined CID in Card Edit for the Cbush elements that I have created, the problem is solved.
Welcome!
Welcome!
