dear all
I made an example. No matter what I set the parameter, there is always penetration. I don't know why.
I learnt that small time step, small gap .etc may cause this problem. But I could not solve it. could you help me?
Try with the model file attached.
Hi, Try with the model file attached.
hi,
Thanks for your help. When I run this, there comes an error. For I uesed version 13.0, I could not run this successfully. Could you help me with this?
You mean I have to made a change of slave nodes and master surface?
Recreate the interface and give a Gapmin value in the interface and try running the analysis and let us know the outcome.
Hi, Recreate the interface and give a Gapmin value in the interface and try running the analysis and let us know the outcome.
Thanks!
I changed the master suface to slave nodes, and changed the slave nodes to master surface. Then there isn't any penetration.
But I don't know whether it is right?
Please download our e book on 'Crash Analysis with RADIOSS' which will give a good insight into all aspects of non linear analysis. It also includes interactive tutorials on contact interfaces and the significance of each parameters associated with it.
Download the e book from this link: http://www.altairuniversity.com/free-ebooks-2/free-ebook-crash-analysis-with-radioss-a-study-guide/
Hi, Please download our e book on 'Crash Analysis with RADIOSS' which will give a good insight into all aspects of non linear analysis. It also includes interactive tutorials on contact interfaces and the significance of each parameters associated with it. Download the e book from this link: http://www.altairuniversity.com/free-ebooks-2/free-ebook-crash-analysis-with-radioss-a-study-guide/
Thank you very much!
