Hello,I‘m a industrial designer .Before use the SolidThinking ,I used Rhino 5.0 .
So I think the move tools in Rhino is more efficient .
In Rhino I can move objects or points exactly from point to point.
It's alway much more convenience.
Hi willwong_cn
Can you give us an example where you are finding it difficult to move an object to a specific location?
Did you try using the tools 'Axis align to NURBS surface' or'Axis align to object'? These tools are handy if you want to move an object to match the location and/or orientation of another object. For example a bottle cap to the top of the bottle.
If you are unable to get the result you are looking for, please post an example here and we can help you.
