Hi everyone,
is there any way to create an ambient temperature, which is defined by a linear function, using Optistruct? After that, I need to define this convection boundary condition to the CHBDYE surface elements. Something similar is discussed in the OS-1085: Linear Steady State Heat Convection Analysis tutorial, but with a constant ambient temperature, which is created on one node, and this boundary condition is applied on the surface elements using that only one node.
Best Regards,
Mert
