Dear Optistruct users,
Currently I am using optistruct in order to optimize a bridge type structure. The objective is to minimize the compliance with a volumeconstraint of 25% of the design volume. I have used a one plane symmetry and after 250 iterations I obtained the following result. To prevent the generation of disconnected sections, I increased the maximum amount of iterations and lowered the object tolerance for the relative convergence criteria. However this had no result. I also have applied a symmetry plane but from the results you can see that the structure not exactly symmetric. Can someone help me to improve my results? your feedback will be highly appreciated.
Michael
