Hi i have only one simple question.
Auf cload in Radioss, is the guten value for every node you select or is the load the value for the sums from all node together
Hi Skaos,
A concentrated load defines a concentrated force applied to each node of a prescribed nodal group. The load is applied to the nodes indirectly by means of a nodal group. The load versus time function is also defined to apply the cload.
Only to getan sure i understand you. Ehen i select 4 no des an a FORcE of 10N every node Haß the force 10
The force is applied to each node individually, so: total force = F(t) * number of nodes.
