hi all,
can anyone pls help me in finding assembly name of a component
thanks in advance
regards,
JAMIE
Hi Jamie,
Select the 'selector' option in Model browser and click directly on the component in the graphics area so that in the model browser the respective assembly and component will be opened.
If you want to get it by tcl:
*createmarkpanel comps 1 'pick a comp' set compname [hm_getmarkvalue comps 1 name 1] set assemlist [hm_assemlist \0] while {[string first [set randname [expr rand()]] $assemlist]!=-1} {} set assemlist [string map [list $compname $randname] $assemlist] set assemcomp [lsearch -all -inline -glob $assemlist *\0$randname] foreach item $assemcomp { puts [lindex [split $item \0] end-1] }
