I was making spot weld connector which requires a property to be assigned to it. Considering the weld properties to be same as the material but what type of card image to be used for the same. I am using radios block format 12.0
Thank you.
Hi Gopal,
Please refer to the RADIOSS help regarding spotweld techniques using type 13 property.
