I am designing a component with topology optimization through Inspire. I don’t know how to set the amount of reticulation of the component. I don’t know how to call it, in other softwares It’s called Material Spreading.
Thanks for your attention
Thanks for the quick reply. The only thing I can do is adding some pictures from other softwares that I used in the past for topology optimization. I would like to regulate the complexity of the shape of the product I am optimizing.
this is most likely what we call 'maximum member size' or 'maximum thickness' in OptiStruct and Inspire.
its function is to avoid a large amount of material in a single zone.
Sorry about the picture in portuguese, but this should help you to avoid large blocky parts.
can you add some pcitures of what are you trying to get from it? honestly i don't know this term.
Ok, very clear, thank you very much !
