Multi-objective Non-linear topology optimization??
Hey everyone,
Does anyone know if Hyperwork take care of multi-objective Non-linear topology optimization? If yes, which software and which feature is being used? Is there are tutorial?
I know Optistruct can do simple non-linear optimization and Hyperstudy has some multi-objective shape optimizing ability. So I guess my real question is how to conduct them together and change it to topo.
Thanks
Hi @Frehab
You can use HyperStudy. Please refer to these tutorials:
HS-4425: Multi-Objective Shape Optimization Study
HS-4450: Multi-Objective Optimization of a Cantilever Ibeam using an Inclusion Matrix
0 -
Thanks for the reply. I DO have checked this tutorial. Is does solve my problem because:
1. it is shape optimization not topo. Not sure if HS can do topo multi-objective optimization as while.
2. it is linear and didn't mention anything about nonlinear. Do you know if HS do have non-linear optimization feature.
0 -
In Hyperstudy you can not perform topology optimization.Two tutorial of multiobjective optimization is available. With Hst you can perform DOE, Fit, Stochastic & Optimization(shape & size only).
Tutorial 4425 covers linear material.so you can perform nonlinear optimization but not topology optimization with Hyperstudy.
0 -
@Rahul RThank you very much
