Problem in using solid map
Altair Forum User
Altair Forum User
In Fig. 1, it is a screenshot of a 3D solid that I plan to mesh, I have a very thin slice at the top (please see circled region in Fig. 2).
1. I meshed the top surface as shown in Fig. 3.
2. I plan to use solidmap to mesh the top slice first, and then mesh the rest of the 3D solid. I select all the surface elements as my source elements, I select the bottom of the top slice as my destination surface. I select one side surface as my 'along geom' (as shown in Fig. 4)
3. After I click mesh, an error message shows up 'Term-face-edge has a srong side-face edge idx' and several faces become white as shown in Fig. 5.
Would you please tell me what is the reason for this? By the way, I first have a rectangular cross section and then I cut the four corners to make it like this.
Thank you very much for your help.
Fig. 1
Fig. 2
Fig. 3
Fig. 4
<?xml version="1.0" encoding="UTF-8"?>image.thumb.png.22d3e91953138de08d13b429c04fd8c2.png
Fig. 5
Welcome!
  • tinh
    tinh Altair Community Member
    edited April 2018
    Hi
    try selecting all slant surfs as 'along'
  • Altair Forum User
    Altair Forum User
    edited April 2018
    Hi
    Hello, Tinh,
    Thank you for your suggestions. I tried to select all the side surfaces as the 'along', but I got the following error:
    The model looks like the following Fig.1. And at the four chopped corners, I have three surfaces there rather than one (Pls see Fig. 2). may I ask if you got any comments on this?
    Thank you.
    Fig. 1
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.2194db1e4100250c147ae6e6938e4f41.png
    Fig. 2
  • Altair Forum User
    Altair Forum User
    edited April 2018
    Another interesting thing is if I jus
    Hello, Tinh,
    <?xml version="1.0" encoding="UTF-8"?>image.png.d614c77ceefb1c3d7cdf2427bbb5000f.png
    Thank you.
    <?xml version="1.0" encoding="UTF-8"?>image.png.b3a1dd9c7895f1fbd88711d6d59b170c.png
    Fig. 1
    Fig. 2
    Another interesting thing is if I just use the setup I showed above for the 'solid map', I set 2 elements in the height direction, but I finally get the following:
    The elements near this region only have half of the height mapped while other parts are mapped from the source to destination with all height, but just 1 element rather than 2 as I wanted.
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.1bb652692ca995c60ac48479d5b47a69.png
    If I select a different chopped region to do the solid map, I got the error saying 'Side face 1: not enough connections to dest face loop'.
    Does this mean there is some strange part in my geometry?
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.7d475c8dcf1d7ea429458c2e74bff23b.png
  • tinh
    edited April 2018
    yes, mapping along surfs may not be successful.
    in your case I think you can simple drag elems to form 3d (panel 3d>drag>drag elems)
Welcome!
Welcome!
