Radioss explicit analysis process completed successfully, 0 errors, 0 warnings but animation file not generating.
Some window of HV Trans is opening and nothing can be done except closing it.
Can you share the engine file created for this run?
Hi, Can you share the engine file created for this run?
Please excuse me. I don't have permissions to share the file. I hope this is OK.
The same RAD file is running without problems and generating A files without any problems in another system.
This problem has been more of an on again off again type.
It occurs sometimes and solves without any problems some other time.
Please try running the files from the RADIOSS solver run manager and let me know if it generates animation files.
Moreover, please upgrade the HyperWorks version to the latest. which is HyperWorks 2017, which has many new features. You can go through http://www.altairhyperworks.com/hw2017/ to know more about it.
For downloading HW 2017 version, please visit https://connect.altair.com/
Hi, Please try running the files from the RADIOSS solver run manager and let me know if it generates animation files. Moreover, please upgrade the HyperWorks version to the latest. which is HyperWorks 2017, which has many new features. You can go through http://www.altairhyperworks.com/hw2017/ to know more about it. For downloading HW 2017 version, please visit https://connect.altair.com/
Running the rad file directly from Radioss too doesn't give any animation output.
Hi Prashanth,
Please share the engine file (file name_0001.rad), as it doesn't contain any model info. The run is completing after starter runs and so please share the engine file as it contains the run controls.
Hi Prashanth, Please share the engine file (file name_0001.rad), as it doesn't contain any model info. The run is completing after starter runs and so please share the engine file as it contains the run controls.
Sorry, my bad. I misread engine file as rad file.
Here's the engine file.
Do you have any engine out file for this run?. If so, please share it.
Hi Prashanth, Do you have any engine out file for this run?. If so, please share it.
These are the last lines in the out file. Which part of the out file are you interested in?
This is the starter out file. Please ensure that the starter and engine file names are the same.
Also, in the RADIOSS solver please upload both the starter and engine files and in options keep it to -both and try running the analysis.
Thanks. Keeping options as 'both' solved the problem.
I'll let you know in case of difficulties in the future.
