Hello!
Is there a way to model a compression only spring / element in optistruct? I want to use these elements to replace the rolling elements of a simplified bearing.
Many thanks in advance.
Max
Hi Max,
Maybe you have to use non linear spring. Refer to PBUSHT property for more information.
