hi i can't seem to find any tutorial (online and among the directory) for optistruct problems (i don't need an optimisation problem i need a non linear quasi static problem) in analysis mode (not optimisation) does anyone have a tutorial? thx
Hi Phil,
We do have nonlinear quasi-static tutorial on the help. You can refer to the below tutorials in v14.0 and above:
OS-1360: NLSTAT Analysis of Gasket Materials in Contact
OS-1365: NLSTAT Analysis of Solid Blocks in Contact
OS-1390: 1D and 3D Pretensioned Bolt Analysis of an IC Engine Cylinder Head, Gasket and Engine Block System Connected using Head Bolts
OS-1392: Node-to-Surface versus Surface-to-Surface Contact
OS-1393: Basics of Contact Properties and Debugging
Thanks,
Vikas
thank you
