I have tried to run numerous simulations for a car spoiler support, however i keep receiving the following error message:
** OptiStruct 14.0 **
** Design and Optimization Software **
** from Altair Engineering, Inc. **
** Windows 8 Workstation (Build 9200) CLN-TS-LIB1-256 **
** 8 CPU: Intel(R) Core(TM) i7-4770S CPU @ 3.10GHz **
** CPU speed 3100 MHz **
** 9991 MB RAM, 18724 MB swap **
** Build tag: 0801293aw733140_Ce64RBW8UH12M:111035-000 4000000004000 **
** COPYRIGHT (C) 1996-2015 Altair Engineering, Inc. **
** All Rights Reserved. Copyright notice does not imply publication. **
** Contains trade secrets of Altair Engineering, Inc. **
** Decompilation or disassembly of this software strictly prohibited. **
*** OptiStruct defaults set from:
install config file: C:\Program Files\Altair\14.0\/hwsolvers/optistruct.cfg.
NOTE # 9199
MSGLMT=STRICT is active, all messages will be printed.
You can suppress some less important warning messages by use of
MSGLMT=BRIEF or UNREF (in config file or in the input data).
*** See next message about line 93695 from file:
//sfs1.qm.ds.qmul.ac.uk/H2/Documents/newtpop/topology optmization work/support2502run
'PSOLID 1 0'
This line was interpreted as:
93695:PSOLID, 1, 0
*** ERROR # 1000 *** in the input data:
Incorrect data in field # 3.
Expected INT > 0, found INTEGER (0).
COMPUTE TIME INFORMATION
EXECUTION STARTED Mon Mar 25 13:32:59 2019
EXECUTION COMPLETED Mon Mar 25 13:32:59 2019
ELAPSED TIME 00:00:00
CPU TIME 00:00:00
*** PROGRAM STOPPED: FATAL ERROR(s) ENCOUNTERED.
***** END OF REPORT *****
For Useful OptiStruct Tips and Tricks, go to the URL:
http://www.altairhyperworks.com/tips.aspx
A fatal error has been detected during input processing:
'PSOLID 1 0'
==== End of solver screen output ====
==== Job completed ====
Any help to get my simulations running would be greatly appreciated.
