Hello, I am starting to learn how Simlab works, so far so good, the only thing I cant figure our is...
If I delete a surface:
1- Lets say I have an outdated copy of those same meshed surfaces, how can I copy that specific surface from the old mesh to the new one?
2- Lets say I make another surface, how can I make the new nodes align with the adjacent surfaces? (so I don't get 'overlapping errors')
3- How can I edit or create an edge-to-fill so that if I use 'fill-edge-command' the right edge will be selected (and not random lines all over the place).
4- How can I undo a deleted surface? what is the deal with ctrl-z?
Thanks For your input, will be bothering you with more questions as time goes on.
AC
