Hi, I meshed my geometry and now I want to export my mesh in XML format. what should I do? I need BCs to be in one XML file and also my whole domain to another XML file. please help me with this
If Hypermesh can't export to your XML format, you can always make yourself a customized template for that.
Show us your XML files if you want some help.
What do you mean by showing my XML files? because I did not make it yet. Also, could you pleas tell me that how I can make customized template? should I write Code for that? and what type of language should I use?
sincerely
But you have to have some idea about this XML, right?
Here's an example for XML used by Siemens NX:
<Nodes Mime='' Url=''> <Node Num='1' X='-1.23978216E3' Y='2.511229351E2' Z='25427.' /> <Node Num='2' X='-1.22156307E3' Y='2.532948137E2' Z='25427.' /> <Node Num='3' X='-1.21863544E3' Y='2.513540115E2' Z='25427.' /> <Node Num='4' X='-1.2166752E3' Y='2.484453106E2' Z='25427.' /> <Node Num='5' X='-1.21021802E3' Y='2.511229351E2' Z='25427.' /> <Node Num='6' X='-1.21368638E3' Y='2.563137087E2' Z='25427.' /> <Node Num='7' X='-1.21887716E3' Y='2.597820727E2' Z='25427.' /> <Node Num='8' X='-1.22500009E3' Y='2.610000002E2' Z='25427.' /> <Node Num='9' X='-1225.' Y='254.' Z='25427.' /> </Nodes> <Elements Mime='' Url=''> <Element Num='1' Family='TNS_4' Type='MINDLIN' Nodes='22;21;24;23'/> <Element Num='2' Family='TNS_4' Type='MINDLIN' Nodes='21;20;25;24'/> <Element Num='3' Family='TNS_4' Type='MINDLIN' Nodes='20;19;26;25'/> <Element Num='4' Family='TNS_4' Type='MINDLIN' Nodes='19;18;27;26'/> <Element Num='5' Family='TNS_4' Type='MINDLIN' Nodes='13;12;15;14'/> <Element Num='6' Family='TNS_4' Type='MINDLIN' Nodes='12;11;16;15'/> <Element Num='7' Family='TNS_4' Type='MINDLIN' Nodes='11;10;17;16'/> <Element Num='8' Family='TNS_4' Type='MINDLIN' Nodes='10;22;23;17'/> </Elements>
So this XML format should be in .... your brain firstly!
Here's my note about XML export from HM:
https://www2.gdtech.eu/wp/2018/02/from-hypermesh-to-xml-format/
HTH,
