Impedance as function of frequency
Altair Forum User
Altair Forum User
Hello ,
 I want to plot impedance graph as a function of frequency for simple wire dipole antenna . I just have started using feko so  I do not have idea how to get impedance graph.
Thank you
Welcome!
  • Altair Forum User
    Altair Forum User
    edited September 2017
    Hello @RG888,
    I would suggest that you look at the Getting Started Guide and the Examples Guide for some help on learning about the basic mechanics of how to use FEKO.  Specifically,
    • 'Examples Guide A-1: Dipole example' will give you an example of a dipole
    • 'Examples Guide A-7: Log Periodic antenna' will give you an example of how to plot impedance over frequency
    I hope that helps! :)/emoticons/default_smile.png' srcset='/emoticons/smile@2x.png 2x' title=':)' width='20' />
    Andries
  • Altair Forum User
    Altair Forum User
    Hello andries,
    Thank you for your suggestions. Yes example guide is good way .
    Finally, I got the plot .
     Thanks
  • Taram
    Taram Altair Community Member
    edited September 2018
    Hello @RG888,
    Andries
    __Hello dear Altair Feko staff. In FEKO exhamples guide, you consider thin dipole (radius/length=1/1000), working at roughly 75 MHz frequency. It is well known, that 'such a dipole has a feedpoint impedance consisting of 73 Ω resistance and +43 Ω reactance' (from wiki). But in your exhamples guide i see
                                                  real part          imag. part            magnitude        phase
    Impedance in Ohm        7.8729E+01       3.6658E+01          8.6845E+01      24.97
    __So in manual Re(Z)=78.7 Ohm and this number differ's from theory. I improved mesh (from 'standard' to 'fine') and performed simulation. I expected Re(Z) to be closer to 73 Ohm. But i've got 81.9 Ohm (see picture below). Can you explain me why can't i approach 73 Ohm value.
    __PS: I am still using old version of FEKO 7.0. May be this is the problem....
Welcome!
Welcome!
