Error #185
having tried a diversity of different already existing and working files to do linear static analysis, I always get the following error warning when starting the optistruct analysis after exchanging the component:
There were 2904 error messages during input processing.
The first message is repeated below:
*** ERROR # 185 ***
Invalid duplicated SPCD entry.
grid id = 1
component = 1
spc set id = 1
I defined the load collectors and the load step newly, gave them new reference number, redid the mesh, even checked the loaded geometry.
Cannot find the problem.
Would be thankful, if someone gave me a hint where to search for the mistake.
Best regards,
H. N.
Looks like you have different load collectors containing same enforce loads with same dof but different magnitude.
Please check this update.
If you still face the problem, please share the model file using file transfer link in my signature below.
0 -
Hi Prakash,
Thanks for your kind respons. Actually, I already checked that, but could not find the real problem. Therefore, I send you the files.
Thanks a lot in advance.
Best regards,
H. N.
0 -
Hi Prakash,
I am sorry, but importing this file via the solver deck (with OptiStruct), I get exactly the same error information.
*** ERROR # 185 ***
grid id = 1
component = 1
spc set id = 10 -
Hi @R. Neumann
I am able to run the file without any error. Can you check if you are using the same file?
I will resend the file again
I am attaching the results file for reference.
If you still face the issue, clear the setting files and try again.
