Hi
i want a tutorail and some examples to learn crash in RADIOSS block 120 i use Hypermesh 12
thanks
HI,
Please refer to HyperWorks help for tutorials on drop, impact, etc.. tests
There are also few examples available in help on crash, impact, etc..
thnk you for your reply i use Hypermesh 12 and i dont get this option : http://cjoint.com/?EByq1JDkGgR in RADIOSS block120 my questions is :
1)where i can get this option in hypermesh 12
2) where i can get some exemples to use this options
They are the engine parameters. From 12.0 first update they are moved to Control Cards.
goto Analysis>> Control cards in RADIOSS.
hii chek an exemple same as this PDF : http://cjoint.com/?EBAuV5Z6z5j but i use Hypermesh 12
you know tutorials same as this PDF
thank you
if you are using 12.0 without any updates Goto Utility browser>> Engine file to add engine parameters.
Recommended:
Please update to the latest patch of HyperWorks 12.0.
You can download updates from http://www.altairhyperworks.com/ClientCenterHWUpdateDownload.aspx?pro_cat=HyperWorks
