I am a new user of Altair Hyperworks and using it for FEA for our university Formula Student team.
When trying to do the analysis for the rear hubs, I couldn't get sensible results and I think that is because I haven't connected two components, which are the hub itself and steel inserts.
I have tried looking for some tutorials or instructions, but couldn't find anything that was helpful for me. So how do I set the contact?
Also my second question is about applying the forces. For example when applying the torque the way I am doing it is taking all the nodes on the surfaces and connecting them to a dependent RBE2 in the centre and then applying the torque to that single node.
Does this make sense or does it create additional stiffness and RBE3 should be used or is there any other way that I should be using for applying the forces?
Thanks a lot,
Justas
