Hi all,
I am Federico and I am trying some Free Size composite optimization simulations. I have seen from the tutorial in the website that the optimization is carried always with the same material (generally UD fabric) with different orientations. If a core has to be considered i have noticed that its orientation is set to 180°. Why this?
I tried to run a simulation considering different fabrics : a UD fabric and a +/-45 Biaxial fabric. I cannot replace the biaxial using +/-45 UD in the model since the carbonfibre types are different (I am considering a high modulus UD and a high strength biaxial fabric).
I tried to run my simulation with both fabrics but the results are questionable. Is it possible to use more fabrics or is it only possible to use a single one with different orientations?
Thanks
