Error during Analysis - Optistrut
Altair Forum User
Altair Forum User
edited November 2020 in Community Q&A
Hallo ,
I planned to implement the BC, Load cases what is exactly in ( Link Provided) in to my model which is already topologically optimized . I applied all the details that are provided and I am getting the following error , Could anyone please provide or check how to rectify the error. I would like to do linear static analysis with my approach in this already topologically optimized model. Thanks in advance . Here with I showed what the error is and also my hm file for your reference .
 *** WARNING 1931:      SPC SID=   4 is not referenced by Case Control.
 *** WARNING # 1848
 Topology optimization without minimum member size control activated.
 Using DTPL card or DOPTPRM,MINDIM is recommended.
 NOTE # 1852
 AUTOMATIC SCREENING is activated.
 Use DSCREEN,AUTO,OFF to disable automatic screening.
 *** ERROR # 339 ***
 The dependent d.o.f. is constrained by grid or spc data.
 RBE3 element id = 34776.
         grid id = 6689.
       component = 2.
 *** ERROR # 339 ***
 RBE3 element id = 34777.
         grid id = 6690.
       component = 1.
 *** ERROR # 329 ***
 RBE3 element 34779 cannot support a x-moment - check element data.
 *** ERROR # 330 ***
 RBE3 element 34779 cannot support a y-moment - check element data.
 *** ERROR # 331 ***
 RBE3 element 34779 cannot support a z-moment - check element data.
 Number of bad RBE3 elements =        3
  • Altair Forum User
    Altair Forum User
    edited April 2017
    Dear Student,
    we could not able to locate your file.
    Can you drop the same on below provided Drop-box link.
    Once you provide the same. we will help you in that case.
  • Altair Forum User
    Altair Forum User
    edited April 2017
    This is Open Forum & anyone can access you file. So kindly share the model Files through 'Drop-box only'
