Hi everyone,
I'm conducting a steady-state heat convection simulation with Optistruct and wondering if I can see the temperatures after the analysis in a text file?
Best Regards,
Mert
Import the result file in to HVSelect the required results in contour panelNow go to query panel and select required nodes and there contour valueClick on Apply and export it as .csv file.
Hi Rahul,
thank you very much for your answer.
